Summary Table
Once an exploration is complete, review a summary of design variables and output response values in tabular format.
From the Design Explorer ribbon, select the Results
Explorer tool.
The Results Explorer browser opens. -
In the Results Explorer browser, select the Summary
Table
tab.
The Summary Table shows a run-by-run summary of the exploration. The columns show the input design variable values for each run and the corresponding response values. -
From the Summary Table, review the design variable values and calculated output
response values at each run.
For Optimization explorations, information about conditions and iterations is also included.
Optimization Summary Table Data
The optimization summary table shows the design variable values along with the calculated objective and constraint values for each run.
Tip: To sort the values in a column by ascending or
descending order, click the column header.
Color Coding
The Optimization Summary table uses color coding to help you determine which designs
are feasible, optimal, and violated. If an iteration contains a
violated constraint, the violated constraint is displayed in a bold font.
- White Background/Black Font
- Feasible design
- White Background/Red Font
- Violated design
- White Background/Orange Font
- Acceptable design, but at least one constraint is near violated
- Green Background/White Font
- Optimal design
- Green Background/Orange Font
- Optimal design, but at least one constraint is near violated
Load Results and Plots
Visualize contours, animations, and plots for each run in the modeling window.
Do one of the following:
- From the Design Explorer ribbon, Evaluate tool group, click the
Results Explorer tool.
- In the Results Explorer browser, click the Summary
Table icon
. - From the Design Explorer ribbon, Evaluate tool group, click the
Run Status satellite icon
- After submitting a simulation, this dialog will open automatically.Note: Using this dialog, individual runs can be contoured while the simulation is still in progress. Animations are not supported from the Evaluation Status dialog.
Right-click on a completed run and select from the following options:
- Load Results from Run [x]: Open the Analysis
Explorer to show results for Run [x]. When loading results from Inspire Motion, the Animation toolbar is displayed. To plot motion results, select Plot Manager
.Restriction: After you leave the Design Explorer tab on the ribbon, the motion plots cannot be saved or viewed. - Open Run Folder: Open the folder for Run [x]. You can review error logs for a failed run.
- Close All Results: Close the Analysis Explorer.
- Apply Variables from Run [x]: Applies the variables used in Run [x] to the current model.
The first-time results or plots are loaded, a second window, plotting client, is opened and the results or plots are loaded. - Load Results from Run [x]: Open the Analysis
