2026
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We recommend fully constraining your sketch when sketch variables are used in the design exploration.
Use the Evaluate tools to run the exploration and review reports.
Use the Results Explorer tool to review results.
Use the Results Explorer tool to review results for DOE.
Discover new features and enhancements.
New to Inspire Cast? Learn the basics here.
Learn to use Inspire Cast with our interactive tutorials.
Create 2D sketches, surfaces, and solids with construction history and variables.
Designate and analyze casting parts, set gravity direction and mold opening direction, define runner system, and configure casting components.
Run a casting analysis to minimize defects and prevent manufacturing problems.
Download the Casting Benchmark Manual to learn more about benchmark and verification tests.
The Design Explorer Browser displays a hierarchical view of your design setup and can be used to enable and disable exploration parameters.
An exploration is a DOE or optimization simulation. Each exploration must include design variables and responses. Optimizations must also include an objective and optionally constraints.
Design variables are changes of the geometric variables that influence the performance of certain analyses.
An output response is a measurement of system performances, such as mass, volume, displacement, or stress.
Goals comprise objectives and constraints.
Export files to the output directory and run the exploration simulations.
Once an exploration is complete, review a summary of design variables and output response values in tabular format.
Visualize the relative effects that design variables and output responses have on DOE explorations.
Predict response values resulting from different design variable choices.
Plot exploration inputs and outputs.
Use the Results Explorer tool to review results for optimizations.
Got questions? We have answers!
