Compensated Geometry
Generate a file whose geometry compensates for expected deformation. The finished product will deform from the compensated geometry into the designed geometry. This tool is available after you have run an analysis.
Export Compensated Geometry
Generate a model with compensated geometry and save it as an .stl file.
First, run an analysis with Compute Deformation enabled.
On the Casting ribbon, select Compensated Geometry
icon.
- In the Export Compensated Geometry window, select a run and then click the Export button.
- Browse to your desired save location and click Save.
