Agents
This option enables you to add, manage and run agents on remote machines.
An agent is required on every machine that is to be monitored for process and network
                information, or for performing remote license server administration tasks.
            - If the Altair Accelerator installation and remote connectivity (ssh, rsh, or vovtsd) to the remote machine are both available, you can use the form on this page to add agents.
- If the Altair Accelerator installation or remote connectivity is not available, you need to set up agents locally on the remote machine
From this page, you can also start all agents and manage existing ones.
        - To learn how to set up an agent via the web interface, go to Add and Configure an Agent using the Web GUI.
- To set an agent up with the CLI, go to Add an Agent – File-Based Configuration.
