Installation
There are four different types of installations available for Monitor.
You will either install with a Single File Distributable (use this if you are ONLY installing Monitor and no other products), or install with Multiple File Bundles, (use this if you are installing several Altair Accelerator products at once). Further, you will install the product according to your operating system, Windows or Linux.
| Platform | Single File | Multiple File |
| Windows CLI Based | lm-win64-cli.exe | win64_bundle.zip |
| Windows GUI Based | lm-win64.exe | |
| Linux | lm-linux64 | linux64.tar, common.tar |
The CLI-based SFD can be used to enable an automated method to push out and execute programs on remote Windows machines. The intent is that a Windows admin would do this and run the SFD with the options required to install it as a Windows service.
To install multiple file bundles, see the Installation Guide.
If an upgrade is required, see Special Considerations for Monitor Upgrades in the Installation Guide.
