Add an Agent – File-Based Configuration
To override default values and create an agent, perform the following steps:
- To configure monitoring agents, go to http://localhost:5555/admin.
Scroll down to Project Configuration Files and click on
taskers.tcl link.
Add the hosts to monitor.
For example:
vtk_ftlm_agent_define HOSTNAME TYPE -rshcmd REMOTECMD -name AGENTNAMEThe value of
HOSTNAMEshould be the DNS name or IP address of the host to be monitored.- For monitoring agents, the TYPE should be
lm. - For license management agents, the TYPE should be
licmgr. - Depending on the connection method desired, the REMOTECMD value should be one of rsh, ssh, or vovtsd.
- If using vovtsd, the argument "-vovtsdport PORT" arguments must be passed as well, where
PORT is the port number on which vovtsd is running
on the remote machine. For
example:
vtk_ftlm_agent_define dragon lm -rshcmd vovtsd -name lmdragon -vovtsdport 16666 - If the Altair Accelerator installation directory location
($VOVDIR) needs to be overridden use the -vovdir option
to specify the desired
vtk_ftlm_agent_define dragon lm -rshcmd vovtsd -name lmdragon -vovtsdport 16666 \ -vovdir /opt/altair/2025.1.0/linux64
When done, click Save.
Once the agent has been properly configured, it can now be started by clicking start all agents.
