Tags
Tags enable you to manage tags and tag data found in the server and in the database.
On the Tags – Server page, you can view the Tags begin tracked in the Server memory. You can delete tags here as well as view active tags.
The Tags Database page has an upper and lower half. The top half shows the tags in the database, and you can delete them, as needed. The lower half of the page enables you to rename a tag and associate it with a specific host site and the tag modification history.
