Synchronous machines – Wound field – Motor Factory – Test environment
Wrong thermal settings for the test "NVH Spectrogram" dedicated to the wound field synchronous machine
The thermal settings should be the same that those available for the test “NVH Working point” (ref.: SLVFXM-17932).
This issue has been corrected.
