Reluctance synchronous machines – Motor Factory – Test environment
Issue in the displaying of the characteristic curves in Jd-Jq area
In the test efficiency map, there is an issue in the displaying of the characteristic curves in Jd-Jq area, where the location of the second working point is wrong (ref.: SLVFXM-17801).
This issue has been corrected.
