EDEM Simulator - Run the Simulation
Once you have set up the model, learn how to run fast and efficient simulations using EDEM Simulator.
Click the
icon on the toolbar to open EDEM Simulator.
Set the Time and Grid options
The first step in running the simulation is to set the Time Step. The Time Step is the amount of time between iterations (calculations). The Time Step value is based on the material properties, and is usually set between 20% of the Rayleigh Time Step for the smallest particle in the simulation at any point in time..
- In this simulation, ensure that the Auto Time Step checkbox is selected and the default Time Integration method is Euler.
Set the simulation time and data write-out frequency.
The simulation time is the amount of real time your simulation represents.
- In the Simulation Time section, set the Total Time to 5 s.
- Set the Target Save Interval to 0.005 s to specify the write-out frequency.
- Enure that Simulator Grid Cell Size is set to 3 Rmin or use the CUDA GPU solver.
Run the Simulation
The last step is to run the simulation.
Click the Start Progress
icon in the Simulation window.
In the Viewer Controls, click the Refresh Viewer
icon or the enable Auto Update
icon at any point to update the Viewer to view the progress of the simulation.
