PARAM, SHELOS11
Bulk Data Entry Allows you to revert to the first order shell element formulation (for CQUAD4 and CTRIA3) used in version 11.0.240 and earlier.
| Parameter | Values | Description |
| SHELOS11 | <YES, NO> |
- In version 12.0, the first order shell elements have been improved
to:
- Eliminate inaccuracies in transverse shear and inter-laminar stress calculation that could occur for cases with membrane-bending coupling, especially composites.
- Improve robustness and stability of buckling formulation by changing the default order for plate buckling to first order.
The behavior of shells from earlier releases can be recovered using this parameter.
