PTFORCE
Bulk Data Entry Defines pretensioning force on pretension section.
| PTFORCE | PSID | SID | F |
| PTFORCE | 3 | 5 | 0.5 |
| PSID | Pretensioning load set
identification number. (Integer > 0) |
| SID | Pretension section
| F | Pretensioning force
applied on this section. (Positive value creates tension). 2 (Real) |
- PTFORCE can be referred by PTADD or by the PRETENSION command in the subcase directly.
- Pretensioning force is actually a pair of forces, applied to the opposite sides of the pretension section. This represents the effect of tightening the nut by a set longitudinal force (which is related to the applied torque).
