PRETPRM
Bulk Data Entry Defines parameters that control initial loading conditions on pretension sections for 1D and 3D bolt pre-tensioning. These parameters also control the printing of diagnostic information about pretension sections.
PRETPRM | PARAM1 | VAL1 | PARAM2 | VAL2 | etc. |
PRETPRM | INILOAD | ZEROF | PRTSW | YES |
PARM# | Name of the parameter | |
VAL# | Value of the parameter |
