Bulk Data Entry Defines non-structural material damping as the sum of
the sets listed.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| NSGEADD |
SID |
S1 |
S2 |
S3 |
S4 |
S5 |
S6 |
S7 |
S8 |
S9 |
S10 |
etc. |
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| NSGEADD |
5 |
10 |
20 |
| Field |
Contents |
SI Unit Example |
| SID |
Non-structural
material damping set identification number. No default
(Integer > 0)
| S# |
Identification number
of non-structural material damping sets defined via NSGE and NSGE1 entries. No default
(Integer > 0, SID ≠
S#)
- Non-structural material damping in this
format must be selected by the NSGE Subcase
Information selector.
- No S# may be the
identification number of a non-structural material damping set defined by another
NSGEADD entry.
- NSGEADD entries take
precedence over NSGE and NSGE1 entries. If
both/all have the same SID, only the NSGEADD
entry will be used.
- Optimization is currently not supported
with non-structural damping.
