PARAM, AMSE4EFM
Bulk Data Entry Controls the activation of the enforced motion static solution in the AMSES solver in conjunction with the normal modes calculation.
| Parameter | Values | Description |
| AMSE4EFM | <YES, NO> | Currently supported for
Modal Frequency Response and Modal Transient Analysis, and can help
speed up the analyses when enforced motion is specified in the model.
- PARAM,AMSE4EFM,YES is supported for Modal FRF and Modal Transient solutions with enforced motion. Viscous damping is also now supported for Modal FRF solution with AMSE4EFM,YES.
- Multiple SPCD sets or multiple modal spaces are not supported in the same model for PARAM,AMSE4EFM,YES.
- Frequency-dependent material are also supported with PARAM,AMSE4EFM,YES.
