PARAM, BUFFSIZE
Bulk Data Entry Defines the maximum size in 8 byte words of the records of data written to the .op2 file.
| Parameter | Values | Description |
| BUFFSIZE | <Integer> Default = 65537 |
- SYSSETTING,BUFFSIZE can also be used instead of PARAM,BUFFSIZE.
- Only the last instance of either SYSSETTING,BUFFSIZE or PARAM,BUFFSIZE in the input file is used, the rest of the entries are ignored.
