DOPTPRM, TMINPLY
Bulk Data Entry Defines the minimum ply thickness allowed for all plies of PCOMPs selected by DSIZE or DTPL design variable definitions.
| Parameter | Values | Description |
| TMINPLY | 0.0 ≤ Real ≤ min(Ti) | Should be smaller than the
                                minimum of all relevant Ti on the selected
                                    PCOMPs. Check its compatibility with volume
                                constraint if applied.  Note: For volume fraction calculation,
                                        TMINPLY is not treated as none design
                                    volume in the same way as T0 for regular
                                        PSHELLs.
Buckling responses for composite structures may be considered for free-size and topology optimization when this parameter is non-zero.  |
