DOPTPRM, MINDENS
Bulk Data Entry Sets the minimum element material density.
| Parameter | Values | Description |
| MINDENS | Real > 0.0 Default = 0.01  |
                            Sets a lower limit on the amount of material that can be assigned to any design element. Extremely low values for this parameter can result in an ill-conditioned stiffness matrix. |
