DOPTPRM, AUTOWGHT
Bulk Data Entry Option to automatically normalize the compliances in the WCOMP response, before applying the weight factors.
| Parameter | Values | Description |
| AUTOWGHT | <YES, NO> | Used to automatically
                                    normalize the compliances in the WCOMP response with respect to
                                    their value at iteration 0, before applying the weight
                                        factors.
- The new weight factors calculated from the input weight factors and the compliances from iteration 0 will be used in the WCOMP response for all the iterations.
