TwoDContact
Class TwoDContact()
TwoDContact(parent='MODEL', name='TwoDContact_n', label='TwoDContact_n',
active=True, contact_type='IMPACT', coulomb_friction='OFF', force_loc='ELEM_CENTER',
create_zero_sensor=False, r_value=0.01, create_hmax_sensor=False, contact_hmax=0.0001,
stiffness=1000, exponent=2.1, damping=0.1, dmax=0.1, penalty=5000, rest_coeff=0.8,
normal_trans_vel=1, use_aug_formulation=True, i_bulk_modulus=160000,
j_bulk_modulus=160000, i_shear_modulus=160000, j_shear_modulus=160000,
i_layer_depth=1000, j_layer_depth=1000, mat_exponent=2.1, mat_damping=1,
b1=None, b2=None, ig=None, jg=None, ig_material_inside=[False], jg_material_inside=[False],
mu_static=0.2, mu_dynamic=0.1, stiction_trans_vel=1, friction_trans_vel=1.5)
    Creates a 2D graphics based contact force between two bodies.
Keyword Arguments
| Argument | Data Type | Description | Default |
| name | String | The variable name. | TwoDContact_n, for next available integer n. |
| label | String | The descriptive label. | TwoDContact_n, for next available integer n. |
| parent | Object | The parent. | MODEL |
| active | Boolean | Used to activate or deactivate this entity. | True |
| contact_type | Enum | The contact type. One of "IMPACT", "POISSON", "USER" or "VOLUME". | "IMPACT" |
| coulomb_friction | Enum | The type of coulomb friction. One of OFF, ON, DYNAMIC_ONLY or USER. | "OFF" |
| force_loc | Enum | The location at which force is computed. One of ELEM_CENTER or NODE. | "ELEM_CENTER" |
| create_zero_sensor | Bool | When TRUE, it creates a zero crossing Sensor to accurately capture the time of first contact for a model containing contact elements. This is useful in getting realistic contact forces without having to run the entire simulation at a small step size. To do this, the sensor monitors the contact force for a contact pair in the model. As soon as contact is first detected, the zero crossing action is triggered. | False |
| r_value | Double | Max step size scale factor. Defaults to 0.01. * create_hmax_sensor (Bool) : When TRUE, specifies the action that the zero crossing Sensor is to undertake when it detects contact (in other words, a zero crossing). The action, in this case, is to reduce the maximum step size the integrator can take. | False |
| contact_hmax | Double | New maximum step size. Defaults to 0.0001. * stiffness (Double) : Applicable for contact_type IMPACT. Specifies the value of the stiffness associated with the contact force. | 1000 |
| exponent | Double | Applicable for contact_type IMPACT. Specifies the value of the exponent for stiffness. | 2.1 |
| damping | Double | Applicable for contact_type IMPACT. Specifies the value of the damping coefficient. | 0.1 |
| dmax | Double | Applicable for contact_type IMPACT. Specifies the value of the maximum penetration depth before full damping is applied. | 0.1 |
| penalty | Double | Determines the local stiffness properties between materials. Larger values lead to reduced penetration between two bodies. Used with the Poisson method of normal force calculation. | 5000 |
| rest_coeff | Double | The value representing the energy loss between the two bodies in contact. A value of one represents no energy loss and a perfectly elastic contact. Used with the Poisson method of normal force calculation. | 0.8 |
| normal_trans_vel | Double | The normal transition velocity. | 1 |
| use_aug_formulation | Bool | Used for the ADAMS solvermode only, to use the augmented Lagrangian formulation. | True |
| i_bulk_modulus | Double | Bulk modulous of I Body material. | 160000 |
| j_bulk_modulus | Double | Bulk modulous of J Body material. | 160000 |
| i_shear_modulus | Double | Shear modulous of I Body material. | 160000 |
| j_shear_modulus | Double | Shear modulous of J Body material. | 160000 |
| i_layer_depth | Double | Depth of material layer of the I Body to be considered for contact force. | 1000 |
| j_layer_depth | Double | Depth of material layer of the J Body to be considered for contact force. | 1000 |
| mat_exponent | Double | The exponent of the force deformation characteristic of the contact interface. Defaults to 2.1 * mat_damping (Double) : The coefficient of damping used to calculate the damping force. | 1 |
| b1 | Body | The first body in the contact force definition. | None |
| b2 | Body | The second body in the contact force definition. | None |
| ig | Graphic | List of graphics associated with body 1. | None |
| jg | Graphic | List of graphics associated with body 2. | None |
| ig_material_inside | Bool | List of booleans which indicate whether there is material inside for every graphic associated with body 1. | [False] |
| jg_material_inside | Bool | List of booleans which indicate whether there is material inside for every graphic associated with body 2. | [False] |
| mu_static | Double | The coefficient of friction when the slip velocity is less than stiction_trans_vel. | 0.2 |
| mu_dynamic | Double | The coefficient of friction when the slip velocity is greater than friction_trans_vel. | 1 |
| stiction_trans_vel | Double | The value where the coefficient of friction becomes ^mu_dynamic^. When the slip velocity is between stiction_trans_vel and friction_trans_vel, the coefficient of friction is in transition between the two. | 1 |
| friction_trans_vel | Double | The value where the coefficient of friction becomes mu_dynamic. When the slip velocity is between stiction_trans_vel and friction_trans_vel, the coefficient of friction is in transition between the two. | 1.5 |
| usr_sub | Function | The expression passed to the user dll for normal force value. When using solver expressions, Templex syntax (within ``) is used and all variables are enclosed in braces {} and the rest is treated as literal. | 'USER()' |
| local_funcname | String | The function/subroutine name for normal force value. | 'CNFSUB' |
| use_local_dll | Bool | Uses a local function instead of default for normal force if True. | False |
| local_dll | File | The path of the local dll for normal force which has the local_funcname. | '' |
| local_func_type | Enum | The type of the user subroutine of normal force. One of DLL, PYTHON or MATLAB. | 'DLL' |
| friction_usr_sub | Function | The expression passed to the user dll for friction force value. When using solver expressions, Templex syntax (within ``) is used and all variables are enclosed in braces {} and the rest is treated as literal. | 'USER()' |
| friction_local_funcname | String | The function/subroutine name for friction force value. | 'CFFSUB' |
| friction_use_local_dll | Bool | Uses a local function instead of default for friction force if True. | False |
| friction_local_dll | File | The path of the local dll for normal force which has the local_funcname. | '' |
| friction_local_func_type | Enum | The type of the user subroutine of friction force. One of DLL, PYTHON or MATLAB. | 'DLL' |
Readonly Properties
| user | Bool | Is True when 'contact_type' is "USER" else False. | False |
| friction_user | Bool | Is True when 'coulomb_friction' is "USER" else False. | False |
