Bushing
Class Bushing()
Bushing(parent='MODEL', name='Bushing_n', label='Bushing_n', active=True,
b1=None, b2=None, fx=0, fy=0, fz=0, tx=0, ty=0, tz=0, origin=None, ornt_meth='TWOAXES')
    Creates a bushing.
Keyword Arguments
| Argument | Data Type | Description | Default |
| name | String | The variable name. | Bushing_n, for next available integer n. |
| label | String | The descriptive label. | Bushing_n, for next available integer n. |
| parent | Object | The parent. | MODEL |
| active | Boolean | Used to activate or deactivate this entity. | True |
| b1 | Body | The first body constrained by the bushing. | None |
| b2 | Body | The second body constrained by the bushing. | None |
| fx | Double | The initial force preload in the local X direction. | 0 |
| fy | Double | The initial force preload in the local Y direction. | 0 |
| fz | Double | The initial force preload in the local Z direction. | 0 |
| tx | Double | The initial torque preload in the local X direction. | 0 |
| ty | Double | The initial torque preload in the local Y direction. | 0 |
| tz | Double | The initial torque preload in the local Z direction. | 0 |
| origin | Reference | The location. | None |
| ornt_meth | Enum | The orientation method. One of TWOAXES, ONEAXIS or ANGLES. | TWOAXES |
| ornt_dir1 | Enum | The direction used to orient axis 1. One of X, Y or Z. | Z |
| align_meth1 | MultiRef | Alignment method for axis 1. One of Point, Vector or DxDyDz. | DxDyDz |
| align_pt1 | Reference | The point when align_meth1 is Point. | None |
| align_vec1 | Reference | The point reference when align_meth1 is Point. | None |
| ornt_dir2 | Enum | The direction used to orient axis 1. One of X, Y or Z. | X |
| align_meth2 | Alignment method for axis 2. One of Point, Vector or DxDyDz. | DxDyDz | |
| align_pt2 | Reference | The point when align_meth2 is Point. | None |
| align_vec2 | Reference | The point reference when align_meth2 is Point. | None |
| e1 | Double | The e1 Euler angle (z:x':z'') in radians with respect to rm. | 0 |
| e2 | Double | The e2 Euler angle (z:x':z'') in radians with respect to rm. | 0 |
| e3 | Double | The e3 Euler angle (z:x':z'') in radians with respect to rm. | 0 |
| rm | Reference | The reference marker when ornt_meth is ANGLES. | Global_Frame |
| x1 | Double | The direction cosine x1 for axis 1. | 0 |
| y1 | Double | The direction cosine y1 for axis 1. | 0 |
| z1 | Double | The direction cosine z1 for axis 1. | 1 |
| x2 | Double | The direction cosine x2 for axis 2. | 1 |
| y2 | Double | The direction cosine y2 for axis 2. | 0 |
| z2 | Double | The direction cosine z2 for axis 2. | 0 |
| usr_type | Enum | User defined bushing type. One of GFORCE, VFORCE, VTORQUE or FIELD. | GFORCE |
| user | Bool | Use user defined properties, if true. | False |
| usr_sub | Function | The expression passed to the user dll. When using solver expressions, Templex syntax (within ``) is used and all variables are enclosed in braces {} and the rest is treated as literal. | 'USER()' |
| local_funcname | String | The function/subroutine name. | 'MOTSUB' |
| use_local_dll | Bool | Uses a local function instead of default if True. | False. |
| local_dll | File | The path of the local dll which has the local_funcname. | '' |
| local_func_type | Enum | The type of the user subroutine. one of DLL, PYTHON or MATLAB. | 'DLL' |
Instances
| Instance | Type | Description |
| kx | Nonlinear | The bushing translational stiffness coefficient in the local X direction. |
| ky | Nonlinear | The bushing translational stiffness coefficient in the local Y direction. |
| kz | Nonlinear | The bushing translational stiffness coefficient in the local Z direction. |
| ktx | Nonlinear | The bushing rotational stiffness coefficient in the local X direction. |
| kty | Nonlinear | The bushing rotational stiffness coefficient in the local Y direction. |
| ktz | Nonlinear | The bushing rotational stiffness coefficient in the local Z direction. |
| cx | Nonlinear | The bushing translational damping coefficient in the local X direction. |
| cy | Nonlinear | The bushing translational damping coefficient in the local Y direction. |
| cz | Nonlinear | The bushing translational damping coefficient in the local Z direction. |
| ctx | Nonlinear | The bushing rotational damping coefficient in the local X direction. |
| cty | Nonlinear | The bushing rotational damping coefficient in the local Y direction. |
| ctz | Nonlinear | The bushing rotational damping coefficient in the local Z direction. |
| i | Marker | The marker on b1. |
| j | Marker | The marker on b1. |
| xaxis | Vector | The vector in x direction of orientation. |
| yaxis | Vector | The vector in y direction of orientation. |
| zaxis | Vector | The vector in z direction of orientation. |
Examples
   >>> # Import mview module
   >>> from hw import mview
   >>> # Create dependancies and references for Bushing
   >>> b1 = mview.Body(name = 'body1')
   >>> g1 = mview.Cylinder(body = b1, origin = 'P_Global_Origin')
   >>> g1.setValues(align_meth1 = 'VECTOR', align_vec1 = 'V_Global_Z',length = 4)
   >>> g1.align_vec1.name
   'V_Global_Z'
   >>> bush1 = mview.Bushing(name = 'bush1')
   >>> bush1.setValues(b1 = b1,b2 = mview.getModel().B_Ground)
   >>> bush1.origin = 'P_Global_Origin'
   >>> bush1.origin.name
   'P_Global_Origin'
   >>> # Set linear stiffness value
   >>> bush1.kx.lin = 100
   >>> bush1.kx.lin
   100.0
   # Set nonlinear curve value for damping
   >>> bush1.cty.type = 'CRV'
   >>> c1 = mview.Curve(x_type = 'VALUE',y_type = 'VALUE',x_value = [0,1,2],y_value = [10,20,5])
   >>> bush1.cty.crv = c1
   >>> #Set interpolation type and independant variable
   >>> bush1.cty.int_type = 'CUBIC'
   'CUBIC'
   >>> bush1.cty.indep_var = '`TIME`'
   # Set stiffness value as expression
   >>> bush1.kty.type = 'EXPR'
   >>> bush1.kty.expr = "`STEP5(TIME,0,0,5,25)`"
   # Follow similar procedure for BushingPair
   >>> b2 = mview.BodyPair(name = 'body1p')
   >>> bush2 = mview.BushingPair(name = 'bush1p',sym = 'LEFT')
   >>> bush2.sym
   'LEFT'
   >>> bush2.setValues(b1 = b1,b2 = 'B_Ground',origin = 'P_Global_Origin')
   # Set linear stiffness value for left bush
   >>> bush2.l.kx.lin = 100
   # Get value of attribute
   >>> bush2.r.kx.lin
   100.0
