General Constraint
Class GeneralConstraint()
GeneralConstraint(parent='MODEL', name='GeneralConstraint_n',
label='GeneralConstraint_n', active=True, expr='``', use_reaction_marker=False,
reaction_marker='Global_Frame')
    Creates a general constraint.
Keyword Arguments
| Argument | Data Type | Description | Default |
| name | String | The variable name. | GeneralConstraint_n, for next available integer n. |
| label | String | The descriptive label. | GeneralConstraint_n, for next available integer n. |
| parent | Object | The parent. | MODEL |
| active | Boolean | Used to activate or deactivate this entity. | True |
| expr | Function | The expression value. | '``' |
| use_reaction_marker | Bool | Use reaction marker when True for SolverMode ADAMS. | False |
| reaction_marker | Marker | Marker reference when use_reaction_marker is True for SolverMode ADAMS. | Global_Frame |
Notes
1. The parent parameter can only be initialized by the constructor and should not be modified directly.
2. Only parent can be used as a positional argument in the constructor.
