Sensor
Class Sensor()
Sensor(parent='MODEL', name='Sensor_n', label='Sensor_n', active=True, value=0, operator='EQ',
error=0, halt=False, restart=False, print_=False, return_=False, codgen=False, yydump=False,
use_stepsize=False, stepsize=0, use_dt=False, dt=0, do_evaluate=False, evaluate_user=False)
    Creates a sensor entity.
Keyword Arguments
| Argument | Data Type | Description | Default |
| name | String | The variable name. | Sensor_n, for next available integer n. |
| label | String | The descriptive label. | Sensor_n, for next available integer n. |
| parent | Object | The parent. | MODEL |
| active | Boolean | Used to activate or deactivate this entity. | True |
| value | Double | The value that the main expression will be compared against. | 0 |
| operator | Enum | The sensor will be triggered when the value is within error, either less than, equal to, or greater than. One of GE, LE or EQ. | EQ |
| error | Double | The tolerance where the main sensor expression and value have to differ within, in order for the sensor to be triggered. | 0 |
| halt | Bool | Causes the solver to stop simulation if set to True. | False |
| restart | Bool | Causes the solver to restart if the sensor is triggered when True. | False |
| Bool | Causes results to be written to the output files at the time when the sensor. | False | |
| return | Bool | Causes the solver to return to the command input for simulation to continue when True. Defaults to False. * codgen (Bool) : Causes the solver to generate a new pivot sequence if set to True. | False |
| yydump | Bool | Causes the solver to export the state variable vector when True. | False |
| use_stepsize | Bool | Use the stepsize provided by stepsize when True. | False |
| stepsize | Double | Resets the stepsize to this if the sensor is triggered. | 0 |
| use_dt | Bool | Use the solver printout stepsize provided by dt when True. | False |
| dt | Double | Resets the solver printout steps to this value. | 0 |
| do_evaluate | Bool | Determines if an evaluation of an expression will occur when a sensor is triggered, and if the expression is determined by a user subroutine or direct expression. | False |
| evaluate_user | Bool | Indicates if the main expression for the sensor will be described directly by an expression or by a user subroutine. | False |
| evaluate_local_funcname | String | The function/subroutine name. | 'MOTSUB' |
| evaluate_use_local_dll | Bool | Uses a local function when True. | False |
| evaluate_local_dll | File | The path and filename for the user subroutine DLL to be used with an instance of the user defined sensor. | '' |
| evaluate_local_func_type | Enum | The type of the user subroutine. One of DLL, PYTHON or MATLAB. | 'DLL' |
| evaluate_usr_sub | Function | The expression passed to the user DLL. When using solver expressions, Templex syntax (within ``) is used and all variables are enclosed in braces {} and the rest is treated as literal. | 'USER()' |
Instances
| Instance | Type | Description |
| expr | Nonlinear | Main expression of the sensor. |
| evaluate_expr | Nonlinear | Expression when do_evaluate is True. |
