Beam
Beam
Class Beam()
Beam(parent='MODEL', name='Beam_n', label='Beam_n', active=True, type='CIRCULAR',
b1=None, b2=None, origin=None, origin2=None, length=0, useautolen=True, E=0, G=0, cratio=0,
OD=0, ID=0, as_=0, p2dim=0, p3dim=0, as2=0, as3=0, area=0, I11=0, I22=0, I33=0,
preload_x=0, preload_y=0, preload_z=0, preload_tx=0, preload_ty=0, preload_tz=0)
    Creates a beam.
Keyword Arguments
| Argument | Data Type | Description | Default |
| name | String | The variable name. | Beam_n, for next available integer n. |
| label | String | The descriptive label. | Beam_n, for next available integer n. |
| parent | Object | The parent. | MODEL |
| active | Boolean | Used to activate or deactivate this entity. | True |
| type | Enum | The type. One of CIRCULAR, RECTANGULAR or ARBITRARY. | ‘CIRCULAR' |
| b1 | Body | The first body attached to the beam. | None |
| b2 | Body | The second body attached to the beam. | None |
| origin | Point | The point at which body_1 is attached to the beam. | None |
| origin2 | Point | The point at which body_2 is attached to the beam. | None |
| length | Double | The length specifies the undeformed length of the beam when useautolen is False. | 0 |
| useautolen | Bool | Indicates that the undeformed length of the beam is calculated automatically using the end points of the beam. | True |
| E | Double | The Young's modulus of elasticity. Defaults to 0. * G (Double) - The shear modulus of elasticity. Defaults to 0. * cratio (Double) - The ratio of the stiffness matrix. | 0 |
| OD | Double | The outer diameter of the polybeam cross section. | 0 |
| ID | Double | The inner diameter of the polybeam cross section. | 0 |
| as_ | Double | The correction factor for the shear deflection for type CIRCULAR. | 0 |
| p2dim | Double | The length of the side along the Y axis for type RECTANGULAR. | 0 |
| p3dim | Double | The length of the side along the Z axis for type RECTANGULAR. | 0 |
| as2 | Double | The correction factor for the shear deflection along the Y axis for type RECTANGULAR and ARBITRARY. | 0 |
| as3 | Double | The correction factor for the shear deflection along the Z axis for type RECTANGULAR and ARBITRARY. | 0 |
| area | Double | The area of cross section of the beam for type ARBITRARY. | 0 |
| I11 | Double | Polar moment of inertia of the beam cross section for type ARBITRARY. | 0 |
| I22 | Double | Second moment of inertia of the beam cross section bout the Y axis for type ARBITRARY. | 0 |
| I33 | Double | Second moment of inertia of the beam cross section bout the Z axis for type ARBITRARY. | 0 |
| preload_x | Double | The preload force in the beam in the X direction. | 0 |
| preload_y | Double | The preload force in the beam in the Y direction. | 0 |
| preload_z | Double | The preload force in the beam in the Z direction. | 0 |
| preload_tx | Double | The preload torsion in the beam in the X direction. | 0 |
| preload_ty | Double | The preload torsion in the beam in the Y direction. | 0 |
| preload_tz | Double | The preload torsion in the beam in the Z direction. | 0 |
Instances
| Instance | Type | Description |
| i | Marker | The marker attached to the first body. |
| j | Marker | The marker attached to the second body. |
Notes
1. The parent parameter can only be initialized by the constructor and should not be modified directly.
2. Only parent can be used as a positional argument in the constructor.
3. Instance is a reference to an entity. You cannot modify an instance, but can modify its properties.
Methods
- getAssociatedGraphics()
Get all the graphics that are associated with this object.
Returns:
List of all graphic associated with this body.
Return type:
(list)
Beam Pair
Class BeamPair()
BeamPair(parent='MODEL', name='VectorPair_n', label='VectorPair_n', active=True, sym='NONE')
      Beam pair containing left and right instances of singles.
Keyword Arguments
| name | String | The variable name. | BeamPair_n, for next available integer n. |
| label | String | The descriptive label. | BeamPair_n, for next available integer n. |
| active | Bool | Defines if entity is activated when True or deactivated when False. | True |
| sym | Enum | The symmetry of pair entity. Takes values 'LEFT' for left entity as leader, 'RIGHT' for right entity as leader, or 'NONE' when it is not symmetric. | NONE |
Instances
| l | Beam | The left Beam. |
| r | Beam | The right Beam. |
Notes
