Template
Class Template()
Template(parent='MODEL', name='Template_n', label='Template_n',
active=True, type='SOLVER_INPUT')
    Templex template.
Keyword Arguments
| Argument | Data Type | Description | Default |
| name | String | The variable name. | Template_n, for next available integer n. |
| label | String | The descriptive label. | Template_n, for next available integer n. |
| parent | Object | The parent. | MODEL |
| active | Boolean | Used to activate or deactivate this entity. | True |
| type | Enum | The type. One of USER, SOLVER_INPUT, SOLVER_COMMAND, SOLVER_PARAM, GRAPHICS, ADAMS, ACF or PROCEDURE. | SOLVER_INPUT |
| text | String | Evaluated text from the template. | '' |
Examples
   >>> from hw import mview
   >>> t = mview.Template()
   >>> t.type = "USER"
   >>> t.text = "ARRAY/ 50000010, NUMBERS = , {ds.veh_end.ival, %d } ! 0 = Front susp."
