TensorFromScalar
Creates a 3D tensor from six scalar tables and stores the result in answer.
- xx
 - A scalar value table.
 - yy
 - zz
 - xy
 - yz
 - zx
 - sysid
 - A system ID or keyword (default = 0).
Outputs
- answer
 - A tensor value table.
- xx, yy, zz, xy, yz, zx and answer must be bound to the same entity type and of the same domain (complex or real).
 - sysid is a string containing an ID or keyword that defines the system
          the tensor will be created relative to:
- “0”: Global (the default)
 - A positive integer: a system ID in the model
 - “elem”: the elemental coordinate system
 - “anal”: the nodal analysis system
 - “ply”: the elemental ply system
 - “mat”: the elemental material system
 - If xx is a constant value table (created by the Constant operator), no records will be added to the answer table.
 - If a record cannot be found in all six input scalar tables, no tensor will be created.
TensorFromScalar(xs,ys,zs,xys,yzs,zxs)XML Example
<call name="TensorFromScalar" xx="xs_tab" yy="ys_tab"
zz="zs_tab" xy="xys_tab" yz="yzs_tab" zx="zxs_tab"
answer="ans_tab" />
