Min
Computes the minimum value of two tables.
- lhs
 - A real value table.
- rhs
Outputs
- answer
 - A destination table to store the minimum of lhs and rhs.
When a corresponding value in one table is not found in the other, this operator returns the existing value.Syntax
min(lhs, rhs)XML Example
<call name="Min" lhs="lhs_tab" rhs="rhs_tab" answer="dest_tab" />
