SquareRoot
Stores the square root of src in answer.
- src
 - A value table.
Outputs
- answer
 - A value table.
- src and answer must be of the same binding and format.
 - If src is a constant value table (created by the Constant operator), no records will be added to the answer table.
 - src must be a real value table and contains any negative values, no value will be placed in the answer table.
sqrt(src)XML Example
<call name="SquareRoot" src="src_tab" answer="ans_tab" />
