BCNodeToSet
Aggregates nodal values to sets.
- src
 - A nodal value table.
 - sets
 - A set entity table.
 - aggregate
 - An aggregation mode (avg, sum, min, max, extreme).
 - pool_name
 - Name of the node pool in the set.
Outputs
- answer
 - An set value table.
- If src is a vector or tensor table, it should be transformed to the global coordinate system.
 - min, max, and extreme aggregate modes are valid only for scalar data.
 - The Expression Builder will auto-fill pool_name with @current_pool (assigned by the application).
 - It is not possible to plot set-bound values in HyperView. A set-bound value must be assigned to elements using BCSetToNode.
BCNodeToSet(src,sets,max)XML Example
<call name="BCNodeToSet" src="src_tab" sets="set_tab"
pool_name="shell" aggregate="max" answer="ans_tab" />
