BCElemToPart
Converts elemental values to part values.
- src
 - An elemental value table.
 - elems
 - An element entity table.
 - aggregate
 - An aggregation mode (avg, sum, min, max, extreme).
Outputs
- answer
 - An part value table.
- If src is a vector or tensor table, it should be transformed to the global coordinate system.
 - min, max, and extreme aggregate modes are valid only for scalar data.
BCElemToPart(src,elems,aggregate)XML Example
<call name="BCElemToPart" src="src_tab" elems="elem_tab"
aggregate="avg" answer="ans_tab" />
