ScaleParticipation
Scales the participation values to ensure that contour patterns stand out.
- projected_participation
 - A scalar or vector value table to be scaled.
 - logrefval
 - A log scaling reference value (1.0, .1, .01, .001, or .0001).
Outputs
- answer
 - A scalar value table.
- projected_participation is the participation component to be scaled for contour.
 - logrefval defaults to 1.0, meaning no log scaling, only scaling by the max value.
ScaleParticipation(projected_participation,logrefval)XML Example
<call name="ScaleParticipation"
projected_participation="projpart_tab" logrefval="1.0"
answer="@usgp_ret" />
