NVToPartRMS
Calculates the RMS value of the absolute value of complex vector components per part.
- src
 - A complex nodal vector.
 - elems
 - An element entity table.
Outputs
- answer
 - A part-bound scalar value table.
- Nodes without values do not contribute to the average.
 - The rms value is computed as follows (per
            part):
sqrt( sum(ss_nv) / num_nv)where:
sum(ss_nv)= sum of squared components of src.num_nv= number of values in each part.
NVToPartRMS(src,elems)XML Example
<call name="NVToPartRMS"
src="nvel_tab" elems="elems"
answer="@ans_tab" />
