*triangle_clean_up
Fixes sliver/bad quality elements which fail the user-defined aspect ratio.
*triangle_clean_up entity_type mark_id criteria_string
HyperMesh Tcl Modify Command
- entity_type
 - The type of input entity. Valid values are elems and comps.
 - mark_id
 - The ID of the mark of input entities. Valid values are 1 and 2.
 - criteria_string
 - There are two possible criteria that can be included in the string:
Examples
To correct all elements failing aspect ratio of 8:
*createmark components 1 "all"
*triangle_clean_up components 1 "aspect=8 height=3"
   # Handle error
}Version History
2019
