*smoothelements
In the automeshing module, applies the specified smoothing operator to the mesh (if any) found on the face for the given number of times.
*smoothelements faceindex smoothmethod iterations
HyperMesh Tcl Modify Command
- faceindex
 - The index of the face into the particular surface under consideration.
 - smoothmethod
 - The smoothing method to use.
- 0 - autodecide
 - 1 - size corrected
 - 2 - shape corrected
 - iterations
 - The number of times to apply the element smoothing operator.
*smoothelements 0 0 25 The undo function for this command is *unsmoothelements().
None.
