*create_thin_solid_midline
Constructs midline of a section cut through selected solids.
*create_thin_solid_midline solid_mark=<mark_id> ?<option1>=<value1>? ?<option2>=<value2>? ... ?<optionN>=<valueN>?
HyperMesh Tcl Modify Command
Constructs midline of a section cut through selected solids. The section cut plane can be defined using one of the following methods: by three nodes/points/sets of coordinates, by four nodes/points/sets of coordinates defining the corners of a finite rectangle or by two sets of coordinates defining the base point and the normal vector of an infinite plane.
- solid_mark=<mark_id>
 - The ID of the mark containing the solids. Valid values are 1 and 2. Non-thin solids will be ignored.
 - node_mark=<mark_id>
 - The ID of the mark containing the nodes defining the cutting plane. The mark should contain 3 or 4 nodes. Valid values are 1 and 2.
 - point_mark=<mark_id>
 - The ID of the mark containing the points defining the cutting plane. The mark should contain 3 or 4 points. Valid values are 1 and 2.
 - plane_by_point_coords={<value>}
 - The value should be a list of coordinates that determine the infinite or finite cutting plane. The array should contain 9 real numbers (3 sets of xyz coordinates) or 12 numbers (4 sets of xyz coordinates).
 - plane_base={<value>}
 - The list containing coordinates of the base point defining the infinite cutting plane.
 - plane_normal=<value>
 - The list containing coordinates of the normal vector defining the infinite cutting plane.
 - dest_comp=<value>
 - This option specifies which component the midlines will be created in:
Examples
*createmark solids 1 131
*createmark nodes 1 10 11 12
*create_thin_solid_midline solid_mark=1 node_mark=1*createmark solids 1 131
*createmark nodes 1 10 11 12 13
*createmark points 1 10 11 12
*create_thin_solid_midline solid_mark=1 point_mark=1 *createmark solids 1 131
*create_thin_solid_midline solid_mark=1 plane_base={1.2 3.4 5.6} plane_normal={7.0 8.0 9.0}
*create_thin_solid_midline solid_mark=1 plane_by_point_coords={1.0 2.0 3.0 4.0 5.0 6.0 7.0 8.0 9.0}
*create_thin_solid_midline solid_mark=1 plane_by_point_coords={0.0 0.0 3.0 0.0 1.0 3.0 1.0 0.0 3.0 1.0 1.0 3.0}
   # Handle error
}Version History
2022
