*CE_FE_CreateUCCFromUCC
Creates a connector control from another connector control.
*CE_FE_CreateUCCFromUCC cc_name cc_existing_name
HyperMesh Tcl Modify Command
- cc_name
 - The name of the connector control to create.
 - cc_existing_name
 - The name of the connector control to use.
Examples
Create a connector control named "my_acm1" from the connector control named "my_acm":
*CE_FE_CreateUCCFromUCC "my_acm_1" "my_acm"
   # Handle error
}Version History
2021
