*setelemqualityparamactive
Sets the on/off state for a specified element quality parameter.
*setelemqualityparamactive param_id activ
HyperMesh Tcl Modify Command
This command is related to the element quality view mode. It sets the on/off state for a specified element quality parameter.
- param_id
 - Specifies the element quality check parameter ID to update. Valid values are:
- 0 - min size
 - 1 - max size
 - 2 - aspect ratio
 - 3 - warpage
 - 4 - max interior angle quad
 - 5 - min interior angle quad
 - 6 - max interior angle tria
 - 7 - min interior angle tria
 - 8 - skew
 - 9 - Jacobian
 - 10 - chordal deviation
 - active
- 0 - Inactive/off
 - 1 - Active/on
Examples
To activate "warpage" parameter:
*setelemqualityparamactive 3 1
      To disable "Jacobian" parameter:
*setelemqualityparamactive 9 0
   # Handle error
}Version History
12.0.110
