*analysisfileset
Loads a results file for use in subsequent operations.
*analysisfileset filename
HyperMesh Tcl Modify Command
Loads a results file for use in subsequent operations. All IDs are assumed to be HyperMesh internal IDs.
- filename
 - The full path and name of the results file.
Examples
To load the result file named C:/my_results/test.res:
*analysisfileset C:/my_results/test.res
   # Handle error
