Setup
Setup data for the simulation using the input file.
Download and use the sample Radioss file (BPillar_Input_Files.zip) to try the DesignAI workflow.
DesignAI allows you to select the primary file for simulation if there are multiple Optistruct or Radioss input files. The Refresh > Hard Refresh option provides you to select the primary file for simulation from the list of input files. The Hard Refresh option will purge the current study data and reset the study to the beginning.
Login to Altair One.
Altair One home page is displayed.
Figure 1. Altair One Homepage -
Click DesignAI in the Favorite
Apps.
The DesignAI page is displayed.
Figure 2. DesignAI PageThe DesignAI page displays the Study Browser on the left and Design Study Workflow on the right.
Click the
at the bottom of the left pane to display the list of DesignAI study files.
The Study Browser with the list of DesignAI study files is displayed.
Figure 3. Study Browser -
Click
to create a folder.
A New Study 1 folder is created.
Figure 4. Study Folder Create -
Double-click the folder name New Study 1 to rename the
folder name.
Figure 5. Folder Name -
Choose one of the following options:
- Drag and drop the input file or a folder.
- Click the Change link to select the files from Altair Drive.
The input file that is uploaded is displayed in the Input Files panel.
Figure 6. Input File for Design StudyIf there are multiple input files, then Model Ambiguity screen is displayed to select the primary file for simulation.Figure 7. Model Ambiguity
- Optional:
Select the model file from the Select Primary Model File
drop-down list and click Okay.
Figure 8. Select Primary Model File
DesignAI parses the input file, extracts, and displays the inputs and outputs of the model.
Figure 9. Model Input File -
All the inputs are selected by default. Click the checkbox next to an input to
exclude it from the simulations.
Note: Click the checkbox next to Label at the top to exclude all the files from the simulation process.
The inputs from the model file are displayed in this pane. Nominal value corresponds to the values in the input file. Lower and upper bounds for Shell Thicknesses are calculated as +-10% while the lower and upper bounds for Shapes are by default -1, 1. You can change these values by double clicking on them. You can also unselect some of the inputs for the dataset. Based on the selected inputs, the number of simulations that will be performed is displayed in the Simulations panel.
Figure 10. Inputs PanelThe Simulations panel displays the simulations progress and its status. By default, the number of simulations is automatically calculated based on the number of inputs selected by the user. This can be changed by editing the Auto field in this panel. Note that higher values will increase the training dataset, potentially improving the ML model. It is not suggested using less than the Auto value as this will decrease the quality of the ML model.
Figure 11. Simulation Cycle -
To enable the curve prediction of an output, toggle the switch of the output to
the right.
Figure 12. Enable Curve Prediction -
Click Execute Simulation.
Figure 13. Execute SimulationNotifications are provided at the top displaying the progress of the simulation. Clickto check more information about the simulation progress.
The Simulations panel also displays the progress of the simulations.
Figure 14. Simulation ProgressThe Setup stage of the simulation is complete, and the simulation files are displayed in the Input Files panel.
Figure 15. Setup Stage Complete
