DesignAI Overview
A brief description of how to launch and use DesignAI.
- Altair Marketplace - Search for DesignAI application in the Altair Marketplace by selecting
My Apps.
Figure 1. Launch DesignAI from MarketplaceClick
to launch the DesignAI application.
Click
to mark this application as favorite to display this application in Altair One Homepage.
- Altair One Homepage - Click DesignAI application
from the Favorite Apps list.
Figure 2. Launch from Altair One Homepage - Altair Drive - Hover over the folder which contains the input file for
simulation, click
Figure 3. Launch from Altair Drive
![](../../images/simulation_screen_1.png)
Figure 4. DesignAI Page
The DesignAI page displays the Study Browser on the left and Workflow on the right.
Study Browser
The Study Browser provides a list of studies for making real-time predictions.
![](../../images/icons/expand_button.png)
![](../../images/simulation_study_browser.png)
Figure 5. Study Browser
The workflow will be displayed on the right once you select the study folder in the Study Browser.
You can create a new study folder by clicking and upload input files in the Input
Files pane that is displayed on the right.
DesignAI Workflow
- DesignAI Workflow - consists of the following
steps:
- Setup
- Train
- Predict Real-time
- Optimize
Figure 6. DesignAI Workflow
Supported Solvers, Inputs and Outputs
Solvers | Files Required | Inputs | Outputs |
OptiStruct | filename.fem file If there are shape variables, then the two shape files (filename_Shape.optistruct.node, filename _Shape.shp) should also be dropped. |
RADIOSS | Either filename.rad, or
filename_0000.rad,
filename_0001.rad are needed. If there are shape variables, then the two shape files (filename_Shape.radioss.node, filename _Shape.shp) should also be dropped. |
