What's New
Here’s a quick look at the latest features available with Altair DesignAI.
Altair DesignAI
Altair DesignAI is a new Altair product that combines physics-based simulation-driven design with machine learning-based AI-driven design to enable teams deliver higher performing products.
Optimization
DesignAI enables you to perform an optimization by updating the input value goals and setting the minimum and maximum values.
Primary File for Simulation
DesignAI allows you to select the primary file for simulation if there are multiple Optistruct or Radioss input files. The option provides you to select the primary file for simulation from the list of input files.
