HyperCrash
M00 File Description
Previous topic Next topic Expand/collapse all hidden text
The M00 file contains the description of Macro-objects, which do not exist in RADIOSS Input. It is useful for HyperCrash. This description refers to objects contained in the D00 Block Format file; a M00 file has no meaning without its associated D00; therefore, if the D00 file is named ROOTNAMED00, then the M00 will be named ROOTNAMEM00.
When some characters or fields appear between parenthesis ( ), then either they are not mandatory or the two forms may appear:
Example 1:
/TREE/ASSEMBLY/assembly_id(/assembly_title)
In the M00 file you may find:
/TREE/ASSEMBLY/1   or   /TREE/ASSEMBLY/2/assembly_title
Example 2:
(UN)CREATED
In the M00 file you may encounter either the word UNCREATED or CREATED.
Connections describe local RADIOSS modeling for entities such as spotwelds. Two notions exist: the elementary connection, which is the description of one spotweld linking a set of parts, and the logical connection, which is a set of elementary connection linking a set of part. This distinction exists for SPOTWELD, BOLT, HEMMING, and WELDLINE.
Hierarchy
This section explains the following keywords:
•/TREE/ASSEMBLY
•/TREE/HPART
•/TREE/SUBPART
•/TREE/PART_ADMAS
•/TREE/PART_RBODY
Assembly
The keyword line is:
/TREE/ASSEMBLY/assembly_id/assembly_title
Where:
Unit
•TREE
is a keyword
Keyword
No
•ASSEMBLY
is a keyword
Keyword
No
•assembly_id
is the identifier number of the assembly
Integer
No
•assembly_title
is the name of the assembly
String
No
Card 1:
1
2
3
4
5
6
7
8
9
10
Nbchild
In the following lines we have Nbchild (Integer) representing IDs of assemblies, physical parts, or subparts.
Card 2:
1
2
3
4
5
6
7
8
9
10
Child1
Child10
Child_ Nbchild
For each ASSEMBLY there is a corresponding /SUBSET/ in the associated D00 file.
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
/TREE/ASSEMBLY/1/Front side frame
     2      2      6
Physical Part
/TREE/HPART/hpart_id/hpart_title
Where:
Unit
•TREE
is a keyword
Keyword
No
•HPART
is a keyword
Keyword
No
•hpart_id
is the identifier number of the HPART
Integer
No
•hpart_title
is the name of the HPART
String
No
Card 1:
1
2
3
4
5
6
7
8
9
10
Nbchild
In the following lines we have Nbchild IDs of subparts.
Card 2:
1
2
3
4
5
6
7
8
9
10
Child1
Child10
Child_ Nbchild
For each HPART there is a corresponding /SUBSET/ in the associated D00 file.
/TREE/HPART/2/Front side frame R
      2
      3       4
/TREE/HPART/6/Front side frame L
      1
      5
Subpart
/TREE/SUBPART/subpart_id/subpart_title
Where:
Unit
•TREE
is a keyword
Keyword
No
•SUBPART
is a keyword
Keyword
No
•subpart_id
is the identifier number of the subpart
Integer
No
•subpart_title
is the name of the subpart
String
No
Card 1:
1
2
3
4
5
6
7
8
9
10
Parent_id
Where:
Unit
•Parent_id
is the identifier of a physical part (/TREE/HPART) or a subset (/TREE/ASSEMBLY).
Integer
No
For each SUBPART there is a corresponding /PART/ with the same ID in the associated D00 file.
/TREE/SUBPART/3/Front side frame R - FR
      2
/TREE/SUBPART/4/Front side frame R - RR
      2
Part of Added Mass
/TREE/PART_ADMAS/parent_id/id/title
Where:
Unit
•TREE
is a keyword
Keyword
No
•PART_ADMAS
is a keyword
Keyword
No
•parent_id
is the identifier number of the parent (assembly, hpart, subpart)
Integer
No
•id
is the identifier number of the added mass
Integer
No
•title
is the name of the added mass
String
No
Card 1:
1
2
3
4
5
6
7
8
9
10
Nbmass
The following cards contains the ID of Nbmass added mass, defined in the associated D00 file:
Card 2:
1
2
3
4
5
6
7
8
9
10
Mass 1
Mass 2
Mass Nbmass
/TREE/PART_ADMAS/7/Stiffner
      1
   1235
Part of Rigid Body
/TREE/PART_RBODY/parent_id/id/title
Where:
Unit
•TREE
is a keyword
Keyword
No
•PART_RBODY
is a keyword
Keyword
No
•parent_id
Integer
No
•id
is the identifier number of the rigid body
Integer
No
•title
is the name of the rigid body
String
No
Card 1:
1
2
3
4
5
6
7
8
9
10
Nbrbody
Where:
Unit
•Nbrbody
is the number of rigid body
Integer
No
The following cards contains the ID of Nodal Rigid Body defined in the associated D00 file:
Card 2:
1
2
3
4
5
6
7
8
9
10
Rbody 1
Rbody 10
Rbody Nbrbody
/TREE/PART_RBODY/8/Stiffner
      1
    567
Theoretical Mass of Part
The theoretical mass is the mass of the part defined in the CAD.
/PART/THEO_MASS/Part_id/mass
Where:
Unit
•PART
is a keyword
Keyword
No
•THEO_MASS
is a keyword
Keyword
No
•Part_id
is the identifier of the part on which the theoretical mass will be applied
Integer
No
•mass
is the theoretical mass of the part (mass defined in the CAD)
Real
Mass
This option is used to give a theoretical value of the mass of the referred part.
Class of Part
/PART/CLASS/Part_id/class
Where:
Unit
•PART
is a keyword
Keyword
No
•CLASS
is a keyword
Keyword
No
•Part_id
is the identifier of the part defined in the input deck
Integer
No
•class
is the class of the part which can be:
•0: special (several classes at the same time) – default value.
•1: fine mesh
•2: fine mesh
•3: medium mesh
•4: coarse mesh
Integer
No
M00 associated to RADIOSS 4.1 fixed format
In the D00 file fixed format, only the following options are written:
•Hierarchy
•Spotweld
•Bolt
•Part of Added Mass
•Part of Rigid Body
•Glue
•Welding lines
•Logical Connection
•Theoretical Mass of Part
•Class of Part
•Dummy
•Belt
Also, specific cards for the hierarchy will be written in the M00 file. These two cards have to be added in the M00 file in order to correctly retain the hierarchy description. These cards do not replace the previous defined ones.
Subset description
/FIXTREE/SUBSET/Subset_id/Subset_name/Nb_child
Where:
Unit
•FIXTREE
is a keyword
Keyword
No
•SUBSET
is a keyword
Keyword
No
•Subset_id
is the identifier number of the subset
Integer
No
•Subset_name
is the name of the subset
String
No
•Nb_child
is the number of the subset(s) defined in this subset
Integer
No
Card 1:
1
2
3
4
5
6
7
8
9
10
Child_1
Child_10
Child_ Nb_child
Where:
Unit
•Child_i
is the identifier number of ASSEMBLY or HPART.
Keyword
No
Subpart description
/FIXTREE/SUBPART/Subpart_id/Subpart_name/PID/MID/Subset_ID
Where:
Unit
•FIXTREE
is a keyword
Keyword
No
•SUBPART
is a keyword
Keyword
No
•Subpart_id
Integer
No
•Subpart_name
Integer
No
•PID
is the property identifier number of the subpart
Integer
No
•MID
is the material identifier number of the subpart
Integer
No
•Subset_ID
is the subset identifier number of the subset where the subpart will be set
Integer
No
/FIXTREE/SUBPART/1/FR BMP BEAM/1/1/51
/FIXTREE/SUBSET/1/FRONT BMP BEAM ASSY/1
     51
/FIXTREE/SUBSET/2/SPOT BEAM TO BRKT L/2
     54      70
/FIXTREE/SUBSET/51/New_physical_part/0
/FIXTREE/SUBPART/54/SPOTWELD/6/0/0
/FIXTREE/SUBPART/70/New_Bolt/26/0/0
M00 associated to NASTRAN file
In the NASTRAN file bulk format, only the following option is written:
•Hierarchy
Go to
Spotweld
Bolt
Glue
Weldline
Hemming
