HyperCrash
Spotweld
Spotweld
Previous topic Next topic Expand/collapse all hidden text
Spotweld
Connections
/SPOTWELD/Nbpoint/id(/title)
Where:
Unit
•SPOTWELD
is a keyword
Keyword
No
•Nbpoint
is the number of part or subpart to weld (Integer < 6)
Integer
No
•id
is the identifier number of the spotweld
Integer
No
•title
is the name of the spotweld
String
No
Card 1: coordinates
1
2
3
4
5
6
7
8
9
10
x_I
y_I
z_I
Where:
Unit
•x_I
Global Coordinates of points defining the position of the spotweld for each part or subpart to weld: one Card for each point. Nbpoint card has to be defined.
Real
Length
•y_I
Real
Length
•z_I
Real
Length
Card 2: Part ID or subpart ID
1
2
3
4
5
6
7
8
9
10
part_1
part_Nbpoint
Where:
Unit
•part_I
is the identifier number of the parts to weld
Integer
No
Card 3: Status
1
2
3
4
5
6
7
8
9
10
Status
Where:
Unit
•Status
Is a keyword which defines the status of the spotweld:
•UNCREATED (1)
•CREATED (2)
The string has to be left justified.
Keyword
No
1.If status is UNCREATED, it means that the spotweld modeling is not in the input deck, but HyperCrash keeps only its geometrical description in the M00 file (Nbpoint, coordinates of points, list of parts to weld).
2.If status is CREATED, the following keyword lines will be written for each spotweld connection:
Card 4: Node ID of the spring
/NODE/Nod_id
Where:
Unit
•NODE
is a keyword
Keyword
No
•Nod_id
is the identifier of one of the nodes of the spring of the spotweld
Integer
No
This keyword line will be written Nbpoint times.
and Np-1 lines with:
Card 5: Spring ID of the connection
/SPRING/spring_id
Where:
Unit
•SPRING
is a keyword
Keyword
No
•spring_id
is the identifier of one of the springs of the spotweld
Integer
No
This keyword line will be written Nbpoint-1 times.
Card 6: Interface ID of the connection
/INTER/inter_id
Where:
Unit
•INTER
is a keyword
Keyword
No
•inter_id
is the identifier of one of the interface of the spotweld
Integer
No
Card 7: Element ID of the connection
/Element/element_id
Where:
Unit
•Element
is a keyword which can be:
•SHELL
•SH3N
Keyword
No
•element_id
is the identifier for one of the SHELL or SH3N element of the spotweld
Integer
No
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
/SPOTWELD/2/3
       -678.822        -449.455          301.25
      1       2
UNCREATED
/SPOTWELD/3/7
       -670.155        -519.814           299.2
       -670.155        -519.814         299.533
       -670.155        -519.814         300.013
      1       2       3
CREATED
/NODE/12844
/NODE/12843
/NODE/12845
/SPRING/7
/SPRING/9
/INTER/53
/INTER/54
/INTER/55
/SHELL/358
/SH3N/1456
/SHELL/567
Go to
M00 File Description for Main Module
