HyperCrash
Main Module Reference Manual
This document presents the details of the directories that exist in HyperCrash and describes the specific HyperCrash files within the directories.
The HyperCrash software contains directories for the following:
•Executable
•Environments
•Configurations
Executable Directory
The directory of the executable files is called $MCRASHEXE.  This is a variable you need to set in your shell environment (csh format):
MCRASHEXE = <ALTAIR_HOME>/hc/bin/<os_type>/
Environment Directories
This directory contains the reference parameter files of HyperCrash.  This directory is unit system dependant.
The environment directory contains different sub-directories according to the output format of the model:
•environment
LSDYNAto output LS-DYNA model
PAM2Gto output LS-DYNA model
RADIOSS_V4to output RADIOSS V4.1, V4.2 and V4.4 model
RADIOSS_V5to output RADIOSS V5.1 model
RADIOSS_V9to output RADIOSS V9.0 model
RADIOSS_V10to output RADIOSS V10.0 model
RADIOSS_V11to output RADIOSS V11.0 model
RADIOSS_V12to output RADIOSS V12.0 model
RADIOSS_V13to output RADIOSS V13.0 model
Each sub-directory contains a list of environment directories according to the unit system:
•environment (LSDYNA, PAM2G, RADIOSS_V4, RADIOSS_V5, RADIOSS_V9, RADIOSS_V10, RADIOSS_V11, RADIOSS_V12, RADIOSS_V13)
▪environment_kgf_mm_s
▪environment_kN_mm_ms_kg
▪environment_N_m_s_kg
▪environment_N_mm_ms_g
▪environment_N_mm_s_T
The directory of the environment files is named $MCRASHDIR.
Configuration Directories
This directory contains the reference parameter files for HyperCrash.
•config
CFGto output CFG model
RADIOSS_V4to output RADIOSS V4.1, V4.2, V4.3 and V4.4 model
The following variables must be defined in order to take into account the selected configuration:
Example for RADIOSS_V4 output format:
MV_VER_DIR = 4.4:4.3:4.4:4.1
MV_CFG_DIR = <ALTAIR_HOME>/hc/config/RADIOSS_V4
Main Module Environment File Description
Specific HyperCrash Input Files
Spotweld File Format Description
Post-Processing Input File
Nastran File Format
ANSYS File Format
Universal File Format
M00 File Description
