HyperCrash
ANSYS File Format
ANSYS File Format
ANSYS File Format
Only the read function is now existing. ANSYS (.cdb) version 5.6 and 5.7 are supported.
The following elements can be read:
•SHELL 43, 63, 93 & 181
•SOLID 95, 45, 72 & 92
•BEAM 4, 24 & 44
•PIPE 16
•MASS 21
ANSYS
RADIOSS
Notes
NBLOCK
double precision nodes
NODE
EBLOCK
SHELL 43
SHELL & SH3N
SHELL 63
SHELL & SH3N
SHELL 93
SHELL & SH3N
SHELL 181
SHELL & SH3N
SOLID 95
BRICK
20 nodes to 8 nodes*
SOLID 45
BRICK
SOLID 72
TETRA4
SOLID 92
TETRA10
BEAM 4
BEAM
3rd node created
BEAM 44
BEAM
3rd node created
BEAM 24
BEAM
PIPE 16
TRUSS
MASS 21
ADMAS
RLBLOCK
PROP/SHELL
Thickness read
PROP/SOLID
Default values assigned
BEAM 4 & 44
PROP/BEAM
Area, Ixx, Iyy & Izz read
BEAM 24
PROP/BEAM
PIPE 16
PROP/TRUSS
Ø & wall thickness read
MASS 21
Mass read
MPTEMP
EX, EY, EZ, NUXY, NUYZ, NUXZ & DENS
MAT/LAW1 & MAT/LAW14
If material is missing or is not supported, default material = LAW2
*20 nodes Solid is transformed into 8 nodes Solid.  20 nodes Hexahedron not yet supported by RADIOSS.
