HyperCrash
Nastran File Format
Nastran File Format
Nastran File Format
The targets of the read and write functions are:
•Import NASTRAN mesh to create a RADIOSS crash model.
•Import NASTRAN model to create a NASTRAN model mainly for:
oStatic analysis
oNVH analysis
HyperCrash reads only the NASTRAN bulk format.
Control cards
The Nastran control cards are just able to read and write without any modification possibilities. These lines are kept in the M00 file.
Header
The Nastran bulk data reading will start from the keyword line:
BEGIN BULK
The lines above this keyword line will be set as control cards.
Read and write entities
The following table shows the read and write entities by HyperCrash. Most of the NASTRAN entities are translated into a RADIOSS entity.
Currently the following NASTRAN cards are supported:
black        : development finish
orange        : under development
red        : development planned
NASTRAN
RADIOSS
NASTRAN
Notes
GRID
GRID*
NODE
GRID
GRID*
CQUAD4
CQUAD4*
SHELL
CQUAD4
ID of CORD is lost
CTRIA
CTRIA*
SH3N
CTRIA
ID of CORD is lost
CELAS1
SPRING
CELAS1
CBEAM
BEAM
CBEAM or CBAR
CBAR
BEAM
CBEAM or CBAR
CROD
TRUSS
CROD
RBE2
RBODY
RBE2
PSHELL
PROP/SHELL
PSHELL
PBEAM
PROP/BEAM
PBEAM or PBAR
PBAR
PROP/BEAM
PBEAM or PBAR
PELAS
PROP/13 or PROP/8
PELAS
CELAS2
SPRING type 13
CELAS2
MAT1
MAT law 1
MAT1
PCOMP
MAT + PROP
MAT1 + PSHELL
FORCE
CLOAD
SPC
SPC1
BCS
CHEXA
BRICK
SHELL16
BRIC20
CHEXA
CPENTA
BRICK
SHELL16
BRIC20
CPENTA
PSOLID
PROP 14
CONM2
ADMAS
CONM2
CTETRA
TETRA4
TETRA10
CTETRA
ASET
GROUP
ASET
PLOAD
MPC
RBE3
RBE3
Displayed as RBODY
CWELD
HyperCrash spotweld
PWELD
PROP type 13
CBUSH
PBUSH
CDAMP (i)
PDAMP
CVISC
PVISC
INCLUDE
CORD2R
SKEW
CORD1R
SKEW
CMASS (i)
PMASS
CONM1
RBAR
RROD
PLOTEL
PBARL
CONROD
SUPERELEMENT
RSPLINE
NASTRAN CONTROL CARDS
KEPT but impossible to modify
Save as text in the M00 file
Spotwelds
The spotwelds of the RADIOSS model are translated with the following FEM NASTRAN model:
•CBEAM + RBE2
•CBAR + RBE2
•CWELD
The spotweld information is written in the <root_name>M00 file.
HyperCrash can translate the previous FEM NASTRAN model to Altair’s spotweld if a <root_name>M00 file can be read during the import of the NASTRAN file.
End of the data
The following keyword line of the end of the file defines the end of the bulk data.
ENDDATA
