HyperCrash
Spotweld File Format Description
This document describes all the spotweld file formats that HyperCrash is able to read.  If you need another specific format, please contact: hwsupport@altair.com
HyperCrash spotweld file
This is a text file with the following cards.  HyperCrash is able to import and export this spotweld file format.
Card 1: spotweld
/SPOTWELD/Nb_part/id
Where:
Unit
•SPOTWELD
is a keyword
Keyword
No
•Nb_part
is the number of part or subpart to weld (Integer < 6)
Integer
No
•id
is the identifier number of the spotweld
Integer
No
Card 2: coordinates
1
2
3
4
5
6
7
8
9
10
x_I
y_I
z_I
Where:
Unit
•x_I
Global Coordinates of points defining the position of the spotweld for each part or subpart to weld: one Card for each point. Nbpoint card has to be defined.
Real
Length
•y_I
Real
Length
•z_I
Real
Length
Card 3: Part ID or subpart ID
1
2
3
4
5
6
7
8
9
10
part_1
part_Nbpoint
Where:
Unit
•part_I
is the identifiers number of the parts to weld
Integer
No
Card 4:
/END
Where:
Unit
•END
Keyword to finish the input.
Keyword
No
Example:
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
/SPOTWELD/2/3
       -678.822        -449.455          301.25
      1       2
/END
User file format 1:.mwf
Id_spotweld::nb_plate::x_coord::y_coord::z_coord::Id_prop_1::Id_prop_2::…
Where:
Unit
•Id_spotweld
Integer
No
•nb_plate
is the number of parts to weld
Integer
No
•x_coord
is the x coordinate of the spotweld
Real
Length
•y_coord
is the y coordinate of the spotweld
Real
Length
•z_coord
is the z coordinate of the spotweld
Real
Length
•Id_prop_i
is the property identifier of the part to weld (2 < i < 5)
Integer
No
•:: (comma)
is the field separator
Character
No
HyperCrash will try to weld the parts linked to the defined property (up to five properties).
Example:
1016::3::2094.178500::-778.072000::781.493150::500::500::125
User file format 2: .mwf
Id_spotweld,x_coord,y_coord,z_coord,Id_prop_1,Id_prop_2,…
Where:
Unit
•Id_spotweld
is the identifiers number of the spotweld
Integer
No
•x_coord
Real
Length
•y_coord
Real
Length
•z_coord
Real
Length
•Id_prop_i
is the property identifier of the part to weld (2 < i < 5) (optional)
Integer
No
•, (comma)
Character
No
Example:
62016,2094.178500,-778.072000,781.493150,1234,6423,4654
62016,1024.13543,-458.0,12.34653
User file format 3: .csv
SPOT,Id_spotweld,nb_plate,x_coord,y_coord,z_coord,Id_prop_1,Id_prop_2,…
Where:
Unit
•SPOT
is a keyword
Keyword
No
•Id_spotweld
Integer
No
•nb_plate
Integer
No
•x_coord
Real
Length
•y_coord
Real
Length
•z_coord
Real
Length
•Id_prop_i
Integer
No
•, (comma)
Character
No
Example:
SPOT,62016,2,2094.178500,-778.072000,781.493150,1265,7532,
SPOT,62016,3,2045.176700,-798.120400,657.486350,1264,7632,18654,
