HyperCrash
.mesh File
.mesh File
Previous topic Next topic Expand/collapse all hidden text
.mesh File
For each physical part declared in the .mcrash file, there will be a corresponding .mesh file.
In each .mesh file the declarations of the nodes, elements will be preceded by a header, which will contain the name of the part, the material name, the mesh class, the CAD design date, and the thickness.
The format of this header is described as follows: The name of a physical part file will be normalized. It will be of the following form:
NAME.mesh
Where NAME is the name of the part in the .mcrash file (no blank character in the name).
Header Format
First line:
#HyperCrash_PART
Where:
Unit
•#HyperCrash_PART
is a keyword. This keyword is left justified.
Keyword
No
After this line, all lines beginning with a # are comment lines.
Parts
For each block describing one part, information will be contained here:
/HPART/part_id/nb_subpart/dd_mmm_yyyy/NAME/Class
Where:
Unit
•HPART
is a keyword
Keyword
No
•part_id
is the identifier number of the part
Integer
No
•nb_subpart
is the number of subpart
Integer
No
•dd_mmm_yyyy
is the reference date defined with :
•dd: day (01 < Integer < 32)
•mmm: month
jan
January
feb
February
mar
March
apr
April
may
May
jun
June
jul
July
aug
August
sep
September
oct
October
nov
November
dec
December
•yyyy: year
Keyword
No
•NAME
String
No
•Class
is the class of the part which can:
•0: special (several class en the same time) – default value.
•1: fine mesh
•2: fine mesh
•3: medium mesh
•4: coarse mesh
Integer
No
/SUBPART/subpart_id/subpart_name
Where:
Unit
•SUBPART
is a keyword
Keyword
No
•subpart_id
is the identifier number of the subpart
Integer
No
•subpart_name
is the name of subpart
String
No
Card 1:
1
2
3
4
5
6
7
8
9
10
PID
MID
Class
Where:
Unit
•PID
is a keyword
Keyword
No
•MID
is a keyword
Keyword
No
•Class
•0: special (several class at the same time) – default value.
•1: fine mesh
•2: fine mesh
•3: medium mesh
•4: coarse mesh
Integer
No
/MID/Mat_id/Mat_name
Where:
Unit
•MID
is a keyword
Keyword
No
•Mat_id
is the identifier number of the material
Integer
No
•Mat_name
is the file name of the material which will be read in the $MCRASHDIR/mat (String with less than 9 characters).
String
No
The name of the material is the same as the file name of the same material in the database.
/PID/type/prop_id/thickness/unit
Where:
Unit
•PID
is a keyword
Keyword
No
•type
is keyword to defined the type of property which can be:
•SHELL
Keyword
No
•prop_id
is the identifier number of the property
Integer
No
•thickness
is the thickness value of the part
Real
Length
•unit
is a keyword which defined the unit and can be:
•mm
•cm
•dm
•m
•inch
•ft
Keyword
No
hmtoggle_plus1Example
#HyperCrash_PART
/HPART/8/0/30_jul_1999/MEMBER_ENG_CRADLE/1
/MID/1/HST440
/PID/SHELL/1/2.00000/mm
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
#HyperCrash_PART
/HPART/76/2/SEATRAIL6S5AAV0_L/2
/SUBPART/1/shell19_jul_1999
      1       1       1
/MID/1/SP
/SUBPART/2/beam
      2       2       0
/MID/2/SP
/PID/SHELL/2/1.20000/mm
Nodes
/NODE/unit
Where:
Unit
•NODE
is a keyword
Keyword
No
•unit
•mm
•cm
•dm
•m
•inch
•ft
Keyword
No
Card 1:
1
2
3
4
5
6
7
8
9
10
NODID
XCOOR
YCOOR
ZCOOR
Where:
Unit
•NODID
is the identifier number of the node
Integer
No
•XCOOR
is the node coordinate value in the first global coordinate system
Real
Length
•YCOOR
is the node coordinate value in the second global coordinate system
Real
Length
•ZCOOR
is the node coordinate value in the third global coordinate system
Real
Length
/NODE/mm
      3      1072.15028      -146.71306        92.20811
      4      1072.15028      -162.30000        92.20811
      5      1083.68673      -162.30000        90.99558
      6      1095.22224      -162.30000        89.78315
Elements
/SH3N/Part_id
Where:
Unit
•SH3N
is a keyword
Keyword
No
•Part_id
is the identifier number of the part or subpart of 3 node shell elements.
Integer
No
Card 1:
1
2
3
4
5
6
7
8
9
10
SH3N_ID
NOD1
NOD2
NOD3
Where:
Unit
•SH3N_ID
is the identifier number of the 3 node shell element.
Integer
No
•NODi
are the identifier numbers of the node connectivity of the element.
Integer
No
/SHELL/part_id
Where:
Unit
•SHELL
is a keyword
Keyword
No
•part_id
is the identifier number of the part or subpart of 4 node shell elements.
Integer
No
Card 1:
1
2
3
4
5
6
7
8
9
10
SHELL_ID
NOD1
NOD2
NOD3
NOD4
Where:
Unit
•SHELL_ID
is the identifier number of the 4 node shell element.
Integer
No
•NODi
Integer
No
/SH3N/1
     13      21       1      10
     15      23      13      14
     21      32      28      33
     22      29      28      34
/SH3N/2
     24      16      31      19
     25      17      18      32
     29      21      38      20
     30      35      37      39
     36      42      43      41
/SHELL/1
      1      11       5       6       7
      2      11       3       4       5
/SHELL/2
      3      12       8       9      10
      4       2       3      11      12
Note: SH3N and SHELL may not share the same ID and can only refer to nodes, parts and/or subparts defined in the same file.
End of the file
End of input data is signalled with:
/END
Where:
Unit
•END
Keyword to finish the input.
Keyword
No
Go to
Specific HyperCrash Input Files
