HyperCrash
Bolt
Bolt
Previous topic Next topic Expand/collapse all hidden text
Bolt
/BOLT/Nb_part1/Nb_part2/Type_bolt/Bolt_id(/Title)
Where:
Unit
•BOLT
is a keyword
Keyword
No
•Nb_part1
is the number of part in the set 1
Integer
No
•Nb_part2
is the number of part in the set 2
Integer
No
•Type_bolt
is a flag which defines the type of bolt:
•0: not defined
•1: rigid bolt
•2: deformable bolt (with spring)
Integer
No
•Bolt_id
is the identifier number of the bolt
Integer
No
•Title
is the name of the bolt - optional
String
No
Card 1: bolt center
1
2
3
4
5
6
7
8
9
10
X_center
Y_center
Z_center
Where:
Unit
•X_center
is the global coordinate value of the geometrical center of the bolt.
Real
Length
•Y_center
Real
Length
•Z_center
Real
Length
Card 2: bolt direction
1
2
3
4
5
6
7
8
9
10
X_vect
Y_vect
Z_vect
Where:
Unit
•X_vect
defines component of the bolt axle in the global coordinate system.
Real
No
•Y_vect
Real
No
•Z_vect
Real
No
Card 3: bolt size
1
2
3
4
5
6
7
8
9
10
Length1
Length2
Diameter
Where:
Unit
•Length1
is the search distance in negative direction on the axle of the bolt.
Real
Length
•Length2
is the search distance in positive direction on the axle of the bolt.
Real
Length
•Diameter
is the search diameter of the bolt.
Real
Length
Card 4: parts list of the set 1
1
2
3
4
5
6
7
8
9
10
Part1,1
Part1,2
Part1,10
Part1,nb1
Where:
Unit
•Part1,i
are the identifier numbers of the parts of the set 1 (10 parts per line).
Integer
No
Card 5: parts list of the set 2
1
2
3
4
5
6
7
8
9
10
Part2,1
Part2,2
Part2,10
Part2,nb2
Where:
Unit
•Part2,i
are the identifier numbers of the parts of the set 2 (10 parts per line).
Integer
No
Card 6: status
1
2
3
4
5
6
7
8
9
10
Status
Where:
Unit
•Status
is a keyword which define the status of the bolt:
•UNCREATED (1)
•CREATED (2)
The string has to be left-justified.
Keyword
No
1.If status is UNCREATED, it means that the bolt modeling is not in the input deck, but HyperCrash keeps only its geometrical description in the M00 file (from Card 1 to 6).
2.If status is CREATED, the following keyword lines will be added:
Card 7: Node ID of the spring
/NODE/Nod_id
Where:
Unit
•NODE
is a keyword
Keyword
No
•Nod_id
is the identifier of the nodes.
In case of deformable bolt, four nodes will be defined:
•both nodes of the spring
•the master node ID of both rigid bodies
In case of rigid bolt, two nodes will be defined:
Integer
No
Card 8: Spring identifier
/SPRING/spring_id
Where:
Unit
•SPRING
is a keyword
Keyword
No
•spring_id
is the identifier of the spring. This card is required only in the case of deformable bolt.
Integer
No
Card 9: Rigid Body identifier
/RBODY/rbody_id
Where:
Unit
•RBODY
is a keyword
Keyword
No
•rbody_id
is the identifier of the rigid bodies:
•Deformable bolt: two cards will be defined
•Rigid bolt: one card will be defined
Integer
No
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
/BOLT/1/0/0/3/susp_arg
        1117.09         557.936             790
       0.042071       -0.254517        0.966153
              5               5              80
 110016
   2478
UNCREATED
/BOLT/1/2/2/1/New_Bolt
         -642.4         486.071         260.389
             -1               0               0
            100             100              40
      1
      3       5
CREATED
/NODE/12883
/NODE/12884
/NODE/12885
/NODE/12886
/SPRING/21
/RBODY/2
/RBODY/3
/BOLT/1/3/1/2/1
      4957.2555        -584.953        1155.805
              0               0               1
            100             100              90
    459
    384     388     389
CREATED
/NODE/328707
Go to
M00 File Description for Main Module
