HyperCrash
Glue
Glue
Previous topic Next topic Expand/collapse all hidden text
Glue
/GLUE/glue_type/param/glue_id(/title)
Where:
Unit
•GLUE
is a keyword
Keyword
No
•glue_type
is keyword which defines the glue type:
•AUTO: automatic glue
•LINE: glue defined with a line
•AREA: glue defined with a contour line
Keyword
No
•param
is the spring property ID of the glue in the D00 file if the glue type is AUTO.
Integer
No
•glue_id
is the identifier number of the glue
Integer
No
•title
is the name of the glue - optional
String
No
The glue with the type AUTO and AREA can be only UNCREATED.
Card 1: Set of part
1
2
3
4
5
6
7
8
9
10
Part_1
Part_2
Gap
Property_Name
Where:
Unit
•Part_1
is the identifier number of the first part to weld
Integer
No
•Part_2
is the identifier number of the second part to weld
Integer
No
•Gap
is the distance value to search the part
Real
No
•Property_Name
is the file name of the springs property of the glue. The spring property file should be stored in the directory $HCRASHDIR/property (text).
Integer
No
Where Property_Name is a string giving the name of the property or the name of the file in which the property will be read.
Card 2: coordinates
This card has to be defined only for type = LINE or AREA
1
2
3
4
5
6
7
8
9
10
x_part_1
y_part_1
z_part_1
x_part_2
y_part_2
z_part_2
Where:
Unit
•X_part_I
Global coordinates of points defining the position of the glue for the both part or subpart to weld: one Card for each point and each point.
Real
Length
•y_part_I
Real
Length
•z_part_I
Real
Length
Card 3: Status
1
2
3
4
5
6
7
8
9
10
Status
Where:
Unit
•Status
is a keyword which defines the status of the glue:
•UNCREATED (1)
•CREATED (2)
The string has to be left-justified.
Keyword
No
1.If status is UNCREATED, it means that the glue modeling is not in the input deck, but HyperCrash keeps only its geometrical description in the M00 file (from Card 1 and 2).
2.If status is CREATED, the following keyword lines will be added for each glue connection:
Card 4: Node
/NODE/Nod_id
Where:
Unit
•NODE
is a keyword
Keyword
No
•Nod_id
is the identifier number of nodes defined in the associated D00 file (nodes of the spring element).
Integer
No
This keyword line will be written twice, for both nodes of the spring.
Card 5: Spring ID of the connection
/SPRING/spring_id
Where:
Unit
•SPRING
is a keyword
Keyword
No
•spring_id
is the identifier of one of the springs of the glue
Integer
No
Card 6: Interface ID of the connection
/INTER/inter_id
Where:
Unit
•INTER
is a keyword
Keyword
No
•inter_id
is the identifier of one of the interfaces of the glue
Integer
No
Card 7: Element ID of the connection
/Element/element_id
Where:
Unit
•Element
is a keyword which can be:
•SHELL
•SH3N
Keyword
No
•element_id
is the identifier of one of the SHELL or SH3N element of the glue
Integer
No
This keyword line will be written twice, one for each nodes of the spring element.
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
/GLUE/LINE/3/16
      3       4        0.000000SPRI_13_Glue
      25.271300       46.455500        0.000000
      25.271300       46.455500        5.000000
      35.271300       46.455500        0.000000
      35.271300       46.455500        5.000000
      45.271300       46.455500        0.000000
      45.271300       46.455500        5.000000
UNCREATED
/GLUE/AREA/4/17
      31.000000       62.000000        0.300000
      31.000000       62.000000        7.000000
      31.000000       47.000000        0.500000
      31.000000       48.000000        8.000000
      50.000000       34.000000        0.000000
      50.000000       33.000000        7.000000
      68.000000       56.000000        0.400000
      68.000000       58.000000        7.000000
UNCREATED
/GLUE/AUTO/0/18/automatic glue
      3       4        20.00000SPRI_13_Glue
UNCREATED
/GLUE/LINE/3/16
      3       4               0SPRI_13_Glue
        35.2713         46.4555            0.75
        35.2713         46.4555             6.2
        25.2713         46.4555            0.75
        25.2713         46.4555             6.2
        45.2713         46.4555            0.75
     45.4872698      45.9418162      6.54751341
CREATED
CREATED
/NODE/586
/NODE/587
/SPRING/1
/INTER/1
/INTER/2
/SHELL/202
/SHELL/317
CREATED
/NODE/588
/NODE/589
/SPRING/2
/INTER/1
/INTER/2
/SH3N/622
/SH3N/667
UNCREATED
Go to
M00 File Description for Main Module
